Cardioidpotent
Microphones can be similar in sound, but there are subtleties that make them different. In the case of the C1 and V67, you have many opinions on both the mics, but in the end, the only opinion that counts is your own.
The Marshall mic does measure differently than ours in the loading, so yes, they will sound different on different mic pres. All mics put out small amounts of voltage measured in millivolts, depending on the impedance of the mic pre, so how it deals with this voltage will determine how it loads.
Yes, our mic pre-amps are matched to all our mics, but that does not mean it can only be used for our mics. Mic pres are hit and miss unless you get one with variable or auto loading capabilities. In the case of
the Vipre, that will cost you big. Joemeek does this automatically, and it is very reasonably priced. Of course you must want to have one of these to control your mics.
In either case, the VT-1 mic pre will be judged by what it is once it hits the streets.
Alan Hyatt
PMI Audio Group
