+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Figure 8 with DEEP null?
  1. #1
    RustyAxe is offline Junior Member
    Join Date
    Sep 2007
    Posts
    90
    Rep Power
    437810
    Question Figure 8 with DEEP null?
    Sign in to disable this ad
    Looking to record a singer/songwriter and am using the "two figure 8 mic" technique to maximize separation between guitar and vocal. Neither of my cheap variable pattern LDCs seem to have a well-defined off-axis null, just enough to know the technique works, but still more bleed than I'd like. Any recommendations for better mics to use? I'd like to keep it under $500 per mic. Thanks!
    - Denny
  2. #2
    bouldersoundguy is offline Three Thousand and Counting
    Join Date
    Mar 2010
    Location
    Boulder, CO
    Posts
    3,195
    Rep Power
    7167592
    If the bleed is from room reflections the pattern is not the problem. As far as I know all figure 8 pattern mics will have a very deep null. Even the ribbons with the squashed pseudo figure 8 have a very strong null that's just narrower than a LDC figure 8. Maybe you could specify which "cheap variable pattern LDCs" you have so we could go look up the polar plot.
  3. #3
    Join Date
    Sep 2007
    Posts
    90
    Rep Power
    437810
    I have a Samson CL8 and an MXL 4000. The room is less than ideal, of course, but that isn't gonna change any time soon. I can't find a polar pattern diagram for MXL, but here's the Samson
  4. #4
    Join Date
    Mar 2010
    Location
    Boulder, CO
    Posts
    3,195
    Rep Power
    7167592
    I found the MXL 4000XL here: MXL® Microphones - MXL 4000XL Extra Large Multi-Pattern Condenser Microphone
    There's a difference in response between the front and back sides of the capsule that does seem to degrade the pattern a bit, if one is to believe the polar plot.
    But I still suspect reflections. No mic will fix that.
  5. #5
    Join Date
    Sep 2007
    Posts
    90
    Rep Power
    437810
    That's a different mic, actually ... there's no pattern plot on the MXL4000 (but I'd think it's similar to the XL). Actually, the MXL (vocal) is doing a pretty decent job of rejecting the guitar, it's the Samson that seems to pick up too much in the off-axis. I'll continue to mess around with the exact placement and angles. Sad thing is ... I got some great tracks last session using a single mic (the MXL). The performer is a seasoned musician and knows how to work a mic ... but he insists on separate vocal and guitar tracks ... and due to an accident MUST play sitting down (putting the mics even closer to each other).
  6. #6
    mixsit is online now Been Here, Posted That
    Join Date
    Mar 2001
    Location
    CatHouseSound
    Age
    63
    Posts
    6,566
    Rep Power
    5832029
    I was curious enough to check out the plots on some of the mics I'm familiar with (a few - a pair of CAD179s and an MP4047 I've been using a bunch exactly like this recently.
    Think this begs the questions though to sort this out a bit. What is the normal' amount of attenuation vs what you're seeing or expected? (they all show about 15-20 at best- That's significant, but again, compared to what?
    Also let's throw in 'what are the back sides pointed at (how dead are those surfaces and how far?
    Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
    (formerly S.P. Technology
  7. #7
    Join Date
    Mar 2001
    Location
    CatHouseSound
    Age
    63
    Posts
    6,566
    Rep Power
    5832029
    Quote Originally Posted by RustyAxe View Post
    T ... and due to an accident MUST play sitting down (putting the mics even closer to each other).
    Oops didn't see that. Ok I hear that. That does seriously cut into how much you get vs what you might like to have
  8. #8
    Join Date
    Sep 2007
    Posts
    90
    Rep Power
    437810
    Quote Originally Posted by mixsit View Post
    I was curious enough to check out the plots on some of the mics I'm familiar with (a few - a pair of CAD179s and an MP4047 I've been using a bunch exactly like this recently. Think this begs the questions though to sort this out a bit. What is the normal' amount of attenuation vs what you're seeing or expected? (they all show about 15-20 at best- That's significant, but again, compared to what?
    I have no idea ... this is the first time I've ever attempted this, just got hip to the technique in past week. Until now I had no reason to use a figure 8 pattern, as I usually record myself vocal/guitar on a single track.
    I'll see what I can do ... any suggestions to reduce reflection into the back side of the mic?
    This is all good stuff. I'm no recording engineer by any means ... just an average musician looking to make decent recordings on the cheap. Thanks all.
  9. #9
    Join Date
    Mar 2001
    Location
    CatHouseSound
    Age
    63
    Posts
    6,566
    Rep Power
    5832029
    Think of it in terms of 'how far are the sources of reflected energy (sides, ceiling, floor-), farther compared to how close the source is always = how much your desired level is vs the 'bleed.
    Just adding some soft baffling ('gobos/partitions) around the micing area- and/or to the rear of the mic in this case knocks down the stuff bouncing in. Obviously larger and/or a treated room fairs better than a smaller one.
    I find in aiming the fig-8s, especially if they're slinging the guitar 'high or they're sitting down you're really kind of juggling the compromises- get closer -for better 'sig to noise, vs best tone (..lots of low boost on high-directional mics!), height and angle options get way restricted..
    One thing having to rotate-aim the null usually aims the back towards the floor or ceiling- a nice up side if there's other instruments in the room
  10. #10
    xaudia's Avatar
    xaudia is offline Junior Member
    Join Date
    Apr 2012
    Location
    York, UK
    Posts
    97
    Rep Power
    1671369
    Most condensers have a frequency-dependent pattern. Figure-8 ribbons generally have very good null points at all frequencies.
    Ribbon mic repairs
    Xaudia.com
+ Reply to Thread
Thread Information
Users Browsing this Thread
Similar Threads
  1. Hot spots and null zones
    By Dani Pace in forum Recording Techniques
    Last Post: 01-06-2010, 06:07
  2. Speakers in a null - Why is this bad?
    By DM1 in forum Mixing Techniques
    Last Post: 11-30-2006, 06:05
  3. 2488 scene/null
    By copperdog in forum TASCAM User Forum
    Last Post: 09-13-2006, 00:25
  4. null
    By stalemayte in forum MP3 Mixing Clinic
    Last Post: 06-15-2005, 21:04
  5. Where's the NULL
    By radiorickm in forum Microphones
    Last Post: 12-15-2003, 19:18
Posting Permissions
  • You may not post replies
  • You may not edit your posts
GearFest Mixing Contest
Biggest Ever Audio Mixing Contest is ON!
