Results 1 to 8 of 8
Thread: EV RE-20 Picking UP Buzz From Computer Monitor?
  1. #1
    Join Date
    Nov 2011
    Posts
    30
    Thanks
    0
    Rep Power
    0
    Sign in to disable this ad
    Can someone explain why this might be happening? I've got a desk boom stand whose base is close to an old cathode ray tube type computer monitor. the mic itself extends pretty far away from the monitor.
    Anyway, I noticed that there was an electrical buzz in the audio recording with the RE-20. I tried turning off the old monitor - luckily I have 2, the 2nd of which is a modern flat screen type. And behold, the buzzing stopped.
    It seems some sort of induction or magnetic interference is causing this buzz. Strangely though, this never happened with my LDCs.
    What is it about a dynamic like the RE-20 that would make it more susceptible to noise interference like this?
    Thanks!
    Ryan
  2. #2
    Join Date
    Aug 2005
    Location
    U.K.
    Age
    33
    Posts
    18,938
    Thanks
    1,112
    Rep Power
    1000000
    Hi Ryan,
    Do you have a multimeter?
    I think it would be normal for any microphone to pick up buzz/hum in close proximity to an old CRT screen, or any mains transformer really,
    but if it's really over the top maybe the chassis of the microphone isn't making contact to the ground pin?
    I can't remember what the setup is in the re20, but it would be worth a check.
    ---------- Steenaudio Website ----------
  3. #3
    Join Date
    Nov 2011
    Posts
    30
    Thanks
    0
    Rep Power
    0
    Quote Originally Posted by Steenamaroo View Post
    Hi Ryan,
    Thanks. I do have a multimeter. But I don't know what I should do with it in this case :-P. Can you give me a clue on that?
    Cheers!
  4. #4
    Join Date
    Feb 2009
    Location
    northampton uk home of Dr Who and Blackstar Amps!
    Posts
    8,769
    Thanks
    1
    Rep Power
    8972962
    CRT displays used "scan coils" saddles of many turns of wire on the neck of the "tube". Through these ran the scan deflection currents of an amp or so of a near sawtooth (aka nasty!) waveform.
    The vertical deflection current would be 50 or 60Hz (bit higher these days). A dynamic mic is a coil of wire! Ideally suited to pickup the radiated magnetic field of the scan current. The mic also has a transformer in it and that does much the same. #
    Capacitor mics are mostly transformerless these days and since the mic element itself does NOT work by electromagnetic induction they are largely immune. Even those capacitor mics with an output traff probably use a "potted toroid" and they are resistant to stray fields.
    Join Date
    Aug 2005
    Location
    U.K.
    Age
    33
    Posts
    18,938
    Thanks
    1,112
    Rep Power
    1000000
    There you go ^. Sometimes I know what, and he always knows why.
    You should have continuity between pin one and either grub screw; The one holding the 3pin in place, or the one in the headbasket.
    I doubt there's a problem, though. They just pick that stuff up pretty well.
  6. #6
    Join Date
    Jan 2006
    Location
    Fremantle, Australia
    Age
    61
    Posts
    5,572
    Thanks
    0
    Rep Power
    11371253
    Every thought about buying a new computer monitor? Several times I get brought files from home studios to mix and the single coil guitar pickup track has a buzz from the old style monitor.
    Alan.
  7. #7
    Join Date
    Feb 2009
    Location
    Posts
    8,769
    Thanks
    1
    Rep Power
    8972962
    Quote Originally Posted by witzendoz View Post
    Alan.
    Yo!! You can pickup a basic jobbie at a charity shop for 15-20. I got a cracking 22" wide screen FSTV for 25 from the Scope shop (VGA and HDMI).
    Join Date
    Nov 2011
    Posts
    30
    Thanks
    0
    Rep Power
    0
    Quote Originally Posted by ecc83 View Post
    Aha! got it, Dave. Traces of my EE classes from college are seeping back in :-P. thanks so much for that explanation!
    R
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 1
    Last Post: 07-11-2011, 00:57
  2. Bass Picking up Buzz
    By Farno in forum Recording Techniques
    Last Post: 01-23-2010, 03:13
  3. Need help picking out a monitor
    By PokerDude422 in forum Gear Reviews & Questions
    Last Post: 07-29-2006, 12:30
  4. Eliminating Buzz from Computer Monitor?
    By Inspired in forum Newbies
    Last Post: 04-22-2005, 08:36
  5. new monitor buzz
    By the edzell in forum Newbies
    Last Post: 10-05-2004, 19:41
Posting Permissions
  • You may not post replies
  • You may not edit your posts
