Results 1 to 10 of 10
Thread: Condenser Mic mounting
  1. #1
    Join Date
    Sep 2001
    Location
    MILWAUKEE
    Posts
    108
    Thanks
    0
    Rep Power
    17
    Unhappy Condenser Mic mounting
    Sign in to disable this ad
    I just purchased a Marshall MXL 2003 condenser mic, this is my first condenser,I havent recieved it yet but my questions are these: I dont have a clue how to mount it some times I've seen em upside down,and vice versa, what is the best way?...Im only recording vocals nothing else, any photos would really help alot. My second question is :is there anything I should be aware of when dealing with a condenser mic (I've got phantom power) Thanks
  2. #2
    Join Date
    Jan 2001
    Location
    Brisbane, Australia
    Age
    31
    Posts
    729
    Thanks
    0
    Rep Power
    58
    It doesn't really matter which way you mount it as long as when you sing in to it you sing into the capsule. So upside or right way up doesn't matter. Also as mentioned in another thread here there is a front and back. Usually the front is the side with the logo and this will have the strongest (loudest)volume. This is the side you want to sing into.
    Condensers are very sensitive compared to dynamics so you don't have to turn the gain up on your preamp as much. With that in mind make sure you don't have any distortion or overloading on your channel.
    Tukkis
  3. #3
    Join Date
    Sep 2001
    Location
    MILWAUKEE
    Posts
    108
    Thanks
    0
    Rep Power
    17
    Thanks for the help..
  4. #4
    Join Date
    Dec 2002
    Location
    Singapore
    Age
    32
    Posts
    10
    Thanks
    0
    Rep Power
    0
    Unhappy
    becareful when u clean it! the coil is really fagile...
    and impact... generally i don't like the condenser because of the extra attention but it does sound nice especially with female vocals...
  5. #5
    Join Date
    Sep 2001
    Location
    MILWAUKEE
    Posts
    108
    Thanks
    0
    Rep Power
    17
    Thanks for the help 2 out of 88 aint bad I guess....
  6. #6
    Join Date
    Mar 2001
    Location
    Victorville, CA
    Age
    65
    Posts
    402
    Thanks
    0
    Rep Power
    1000
    I think the reason you will see a lot of condensers mounted on a boom stand and hanging upside down is because they are usually susceptible to handling noise. By hanging them upside down there is less chance of them being bumped by the singer.
    Blessings, Terry
  7. #7
    Join Date
    Oct 2002
    Location
    Da Thumb
    Age
    63
    Posts
    1,195
    Thanks
    0
    Rep Power
    67519
    They're sensitive - you probably want shock mounts. The Sound Room has generics if you don't have mounts made for your mic. I'm reasonably happy with mine, though they're set up for larger diaphragms.
    Good luck.
  8. #8
    Join Date
    Mar 2001
    Location
    Victorville, CA
    Age
    65
    Posts
    402
    Thanks
    0
    Rep Power
    1000
    Wow, those are $50!
    Most of the companies offer custom mounts for their products for less than that.
    I agree that shock mounts are important though.
    Blessings, Terry
  9. #9
    Join Date
    Apr 2002
    Location
    Framingham, Mass. (near Boston)
    Age
    63
    Posts
    6,832
    Thanks
    0
    Rep Power
    21474859
    They used to hang mics upside down to keep the heat from the tube from affecting the diaphragm, and I would still hang a tube mic that way. With a FET condenser, it doesn't make a rat's ass bit of difference. It probably doesn't matter much with current tube mics either, as mylar, built for space applications, is less sensitive to heat than gold foil. Yeah, shock mounts are a good thing. Check the diameter of the mic and get an appropriate shock mount. Rode makes some passable generics that will fit most mics, including your MXL. I think they're closer to $30. I do have those Sabrasom mounts from the Sound Room for my MC012's, though, and they are quite versatile.-Richie
  10. #10
    Join Date
    Apr 2001
    Location
    op ks
    Age
    49
    Posts
    5,887
    Thanks
    0
    Rep Power
    0
    upside down, looks better. I found it is also cheaper to bolt the mic flanges to the ceiling and use gooseneck extensions instead of stands for overheads and vocals.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
