Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Cad M179 hum?
  1. #1
    Join Date
    Jun 2007
    Location
    Connecticut
    Posts
    23
    Thanks
    0
    Rep Power
    0
    Cad M179 hum?
    Sign in to disable this ad
    I've noticed that my Cad M179's both seem susceptible to hum in the area of the pattern selection switch. If you put your finger near the switch the hum increases. It doesn't seem to be related to cabling issues.
    Has anyone else noticed this?
    -Keith
  2. #2
    Join Date
    Mar 2006
    Location
    ▲ ☻ Oregon, USA ☻ ▲
    Posts
    872
    Thanks
    0
    Rep Power
    115720
    Not me, mine are DEAD silent. The self noise (including hum) are very low to non existant. So, no it's not normal as far as I can tell.
    What are you using for phantom power?
    Maybe your mic has been damaged. The pattern selection switch changes the pattern by mixing in the 2nd diaphragm. If something came disconnected back there it could instead mix in the 50/60hz hum instead.
    I would try the mic on a different cable and phantom power source (preamp).
  3. #3
    Join Date
    Jun 2007
    Posts
    113
    Thanks
    0
    Rep Power
    16305
    Quote Originally Posted by Testing123
    -Keith
    I had one that did the same thing, exactly. CAD tech support said it was a faulty capacitor. Contact them and I'm sure they will take care of you.
  4. #4
    Join Date
    Apr 2005
    Location
    In a bucket
    Posts
    2,224
    Thanks
    41
    Rep Power
    2694713
    I've got one of them. Just to add, no problems like that with mine. Isolated incident.
    I really...really...REALLY have no idea what I'm talking about...AT ALL.
  5. #5
    Join Date
    Jun 2007
    Location
    Connecticut
    Posts
    23
    Thanks
    0
    Rep Power
    0
    Thanks for the replies. I tried a few different cables. I have one set of cables that have the shield tied to the shell at the microphone end, and one set that don't - neither behaved any differently.
    I'd think if it was a phantom power problem it would hum all the time, but maybe not. I'll check that out.
    I sure don't remember them behaving that way when I first got them, but I can't recall if I ever changed the pattern while I was listening.
    If everything else checks OK I'll give CAD a call.
    -Keith
  6. #6
    Join Date
    Jun 2007
    Location
    Connecticut
    Posts
    23
    Thanks
    0
    Rep Power
    0
    Just wanted to follow up... this ended up being somewhat of a case of operator error. I realized later that I was set up VERY close to a 240VAC power line in the floor under where I was testing. Putting my finger on the pattern switch in such an intense field from the power line was just too much.
    I've since used the mics in some really quiet environments (i.e. recording classical music) and no sign whatsoever of any hum.
    -Keith
  7. #7
    Join Date
    Dec 2004
    Location
    Sunnyvale, CA
    Age
    41
    Posts
    5,743
    Thanks
    0
    Rep Power
    3408650
    Quote Originally Posted by Testing123 View Post
    Mics shouldn't care about a power line under your floor. If you can still reproduce the problem in the original spot, that probably indicates that the body of the mic isn't properly grounded, which is a safety issue. Drop CAD a line and see what they think.
    Quote Originally Posted by Obi-Wan
    If you mod me down, I will only grow stronger.
  8. #8
    Join Date
    Nov 2004
    Posts
    5,661
    Thanks
    0
    Rep Power
    441890
    Quote Originally Posted by dgatwood View Post
    the one i had with the humming problem would give off a little shock sometimes.
  9. #9
    Join Date
    Oct 2005
    Posts
    1,684
    Thanks
    0
    Rep Power
    854190
    -Keith
    It is a ground loop issue. Somewhere in the circuit there is a ground potential problem. IE: the ground of the mic/preamp circuit is not 0 V compared to someother ground. This is what causes the hum to get stronger and could potentially cause shocking if severe.
    What are you running the mic into? What is the signal chain? This is important to know.
    [COLOR=DarkSlateBlue]"Tascam, Fostex or Studers don't make hit records...........people do"[/COLOR]
    MCI2424 - 2007
  10. #10
    Join Date
    Dec 2004
    Location
    Sunnyvale, CA
    Age
    41
    Posts
    5,743
    Thanks
    0
    Rep Power
    3408650
    Quote Originally Posted by MCI2424 View Post
    Maybe, but if only one mic hums and other condensers don't, it is probably a failed body ground. At most you'll get the leakage across some of the power regulation circuitry in the mic (probably a couple of volts) unless some other part fails and you get a 48v short to the case, in which case you could then get a nasty shock. Not much amperage, but you'd still feel it....
Thread Information
Users Browsing this Thread
Similar Threads
  1. Cad M179 and GXL 3000
    By Mikey77 in forum Microphones
    Last Post: 06-01-2007, 22:23
  2. AT4040 Vs CAD M179
    By prestomation in forum Microphones
    Last Post: 01-06-2006, 15:06
  3. The CAD M179 in context . . .
    By Kelly Dueck in forum Microphones
    Last Post: 06-23-2004, 10:30
  4. pair of 666s and a cad m179
    By eeldip in forum Free Ads for Music/Recording Equipment
    Last Post: 06-07-2004, 16:07
  5. CAD M179 Mic
    Last Post: 06-26-2001, 19:03
Posting Permissions
  • You may not post replies
  • You may not edit your posts
