CAD Equitek E200 mic capsules
Andybot
Member
Hi,
i was wondering if anyone had a part number for the primo mic capsules that were used
in the original e200 mics( if they are still available) or if there was a modern replacement that would work in this mic.
Also ditto for the e100-2 mic but i beleive that is a transound TSB 160A which is still
available.
Thx All
Found this in an old 1997 SOS article:
"The E200 uses a pair of the same back-electret capsules as the E100, and these are mounted in a similar way, on rubber cross arms between two vertical metal pillars. The capsules are arranged back-to-back, but with a space between them and a separation between front faces of 25mm or so."
https://www.soundonsound.com/sos/1997_articles/jun97/cadequitek.html
Hope it is helpful. Although I feel it may not, since it does not reference the 100-2 specifically.
Dale
More info from RecordingHacks: CAD Audio e100<sup>2</sup> | RecordingHacks.com
Thx Dale, i contacted primo and they couldnt/wouldnt confirm which module they used in
the e200. Im suprised that no one seems to have tried different modules in this mic but its maybe to
expensive a mic to be messing with like that.
Thx
