Kristian
That is exactly where my mic came from. I emailed them to see if they had any more info on it and this is what came back.......
Dear Mark,
If you can find a web site called "Soundelux" in Germany, you will find the same mic. (Very expensive in Europe). I suppose you would call it a specialist vacuum tube mic that has a characteristic sound you can only get with lots of capacitors, coils, transformers and a pre amp tube. (Bit like a Marshall really)
That does not mean that it has technically good distortion figures, low noise or other apparently desirable specs. The reason people like tube mics is the reproduction process tends to give favorable enhancement to even order harmonics and suppresses odd order harmonics. The result is a "warm" and crisp sound that suits certain vocal and instrumental recording situations.
.......anyway I've looked for Soundelux and obviously can only find the USA mob. Does anyone know of a European Soundelux?
